THEMA: Adoption of V200 SBModellbau motor kit(photo)
Vadim - 04.08.11 12:09
Hello.
My Trix V200 3 pole motors was not so good. They often loose contact or made shorts between commutator segments.
The difficulties of installing this kit are:
1) No screw holes  at cyllindrical surface of motor.
2) Motor is a little bigger than it must be.
STEPS:
1)  Milling of body is the same:
http://img-fotki.yandex.ru/get/4516/5475818.6/0_5de4f_3e5cc017_L
2) Making a fitting from side screw holes on motor to body:
http://img-fotki.yandex.ru/get/4409/5475818.6/0_5de53_c2ff2a9e_L
http://img-fotki.yandex.ru/get/5810/5475818.6/0_5de4c_90b575ef_L
Attaching it to body by 4 screws:
http://img-fotki.yandex.ru/get/5810/5475818.6/0_5de4e_6dc0a87f_L
Remooving extra height of motor :
(Additional lowering of motor can block trucks gear).
http://img-fotki.yandex.ru/get/4706/5475818.6/0_5de51_d1b9b8f3_L
Assembling it:
http://img-fotki.yandex.ru/get/4517/5475818.6/0_5de50_8f225e47_L
Ready lok:
http://img-fotki.yandex.ru/get/4912/5475818.6/0_5de4d_71ba1c97_L
Vadim
Очень хорошо. Каково теперь качество при медленной езде?
[ Eglod told : How about quality of loco  motion at slow speeds using maxon motors ]
Hello Eglod!
1) I had an equally good quality of motion  at all range of speeds with serviced or new (MiniTrix)  motors as well as  with Maxon motors.
2)The reason of motor change is  a short lifetime between servicing of MiniTrix motors.
3)Now, with Maxon motors,  i have quality as with new  MiniTrix motors, but supply current is lower.
4)Maxon motors will remain this quality for significantly more long perion with comparison of usual(Minitrix) motors.
4A) This degradation concerns only motors from V200(m62) -[3 poles] and ICE-1 [5 poles]. I serviced it(cleared collector) many times. Motor in MiniTrix E40 loco works well. I newer serviced it yet.
5) Stalling at  slow speeds can occur due to poor current pickup of loco  and havent any deal with motor quality.  This problem must be solved by springing axles,
see there:
http://www.youtube.com/watch?v=N-jtZsHNL_Y
And result:
http://www.youtube.com/watch?v=bYcpFB3V0zg
EXAMPLE:
How to make in Brava BR 232(Ljudmila):
http://fotki.yandex.ru/users/vadimav/album/119099/
And using USP powerpacks and decoders with "Read-Through" trchnology. (read commands through isolator)
See there for H0:
http://www.youtube.com/watch?v=2f2hmeNNCOs&...p;list=LLT5G0_8Szfx4
EXAMPLE:
How to install powerpack for N-Scale  BR101:
http://fotki.yandex.ru/users/vadimav/album/98295/
5A) Nonuniform behaviour of  loco speed, causing by dirty collector,   having at slow speeds  will remain at high speeds.
6)Mini Trix (and other ) Motors have 2 main disadvantages:
6A) Backlash of  brushes. Low quality of brushes graphite and copper of  lameles. This backlash lead to form sharp edge of brushes  when motor is mooving at one side. And when loco is reversing their direction -  this graphite sharp edge goes between lameles,crackes, and cause short circuit.  This graphite dust between lameles can cause strong degradation of  BEMF, and, therefore, cause very ununiform motion of loco.
6B)Probably, if You moove loco only in one direcrion and newer reverse it - motor lifetime must be higher. As to me - I have all locos with reversing.
6C) Plastic spacers betweel lameles wears with slower rate and can cause loosin of contact between lameles and  brushes.
Vadim.
Thank you for the very interesting information.
Ok. I m glad if my information and experience  can help to somebody.
Vadim
