THEMA: Minitrix BR 52. 12303 DCC Sound ?
Paul.H - 07.01.16 00:47
Hi sorry for English, I am British. I purchased a BR 52 for my collection as analog, however when I went to lubricate I found a DCC sound decoder soldered in it. Does anyone know what make it is ? Loksound? I find myself unable to program it , I can switch it to run on analog but I can not program it for DCC. When I input some CVs the loco beeps but it will not respond to the controller on the track. Can anyone help?
Die von Paul.H zu diesem Beitrag angefügten Bilder können nur von registrierten Usern gesehen werden - Login
Hi Paul,
this is the SL75 from CT-Elektronik / Tran. See 1001-digital.de for more info (site is in german).
Best regards
Best regards
Hi Carsten,
Thank you, it is indeed the SL75. I have investigated further and I believe that I am able to program it. However the issue is that the loco doesn't respond to a command once it is running unless I tip it so that one side of the locos wheels loose contact with the track. Example if I have it running forward and select reverse , nothing happens until I tip the loco then when it is back on the track it then changes direction. Could this be a wiring fault ? The joints look OK.
