THEMA: Fleischmann br 602 (7770001)manufacturing errors
Mr.Bean - 22.01.24 18:19
Hello,
I come from China, I am very happy to communicate here.
I purchased a set of Fleischmann BR 602. However, I found an error. On the document, which clearly indicates that the electrical coupling is located on the 901 203-0 car. In reality, the electrical coupling is on the 901 106-5 car. This will cause the vehicles to be unable to couple correctly. Has anyone else encountered this issue?
Thank you!
Die von Mr.Bean zu diesem Beitrag angefügten Bilder können nur von registrierten Usern gesehen werden - Login
Hier dieÜbersetzung :
Ich komme aus China, ich bin sehr glücklich, hier zu kommunizieren.
Ich habe einen Satz Fleischmann BR 602 gekauft. Ich habe jedoch einen Fehler gefunden. Auf dem Dokument, das deutlich anzeigt, dass sich die elektrische Kupplung am Auto 901 203-0 befindet. In Wirklichkeit ist die elektrische Kupplung auf dem 901 106-5 Auto. Dies führt dazu, dass die Fahrzeuge nicht in der Lage sind, richtig zu koppeln. Ist noch jemand auf dieses Problem gestoßen?
Leider hab ich den Triebzug nicht.
Gerald
Hello Mr. Bean,
you are obviously right that Fleischmann made a mistake by causing a difference between the printed instruction sheet and model assembling.
But in reality there happened several changes in lashing up the passanger coaches between the motor cars.
So you just should connect the electrical coupling to the motorized car and exchange the cars you mention by number.
And then have fun with this amazing train!
Regards
Hello,Karl
Thanks for your reply, but this would lead to differences with the actual vehicle.
Hello Mr. Bean,
i had the same problem. Put the coach with the elecrtical coupler with this coupler to the motorized car. I do it this way and i have no problems in this case with this train.
The instruction is not correct.
But do you know that there is another problem with this trainset? They put in two restaurant coaches but no bar coach. As i know Fleischmann will fix this. So contact your dealer about this fact.
https://www.1zu160.net/scripte/forum/forum_show.php?id=1383984&start=9#aw25
Gruß, Oli
Hello Oil,
I am aware of this issue, have sent an email to fleischmann, and are tracking the situation. Thank you for your reminder.
Regards
Bean
Hello,
thanks for the photographs, Mr. Bean.
Besides the other topics the inaccurate painting / printing of your coaches are a little underwhelming: On one coach (901 106) the red area includes the frame, on the other coach (901 203) the red area ends with the chassis. I wonder, how these two coaches look like when coupled together. How does the other coaches are painted? Could you provide more pictures?
Regards,
Hallo GemeiNde,
Ich hole mal diesen älteren Fred wieder hervor. Meine Frage betrifft allerdings die analoge Variante mit der Artikelnummer 776001. Ich überlege mir derzeit, dieses Modell zu erwerben.  Hat zufällig jemand den Triebzug bereits und kann mir sagen, ob die Wagen jetzt richtig ausgeliefert werden? Eine Nachfrage bei Kramm vor einigen Wochen wurde leider bislang nicht beantwortet.
Viele Grüße und ein frohes Osterfest wünscht
Albert
Hallo Albert,
ich kann dir nicht sagen, ob die aktuell ausgelieferten Triebzüge mit den korrekten Wagen ausgeliefert werden. Ich jedenfalls habe heute den korrekten Barwagen ohne Türen vom Händler meines Vertrauens erhalten.
Du kannst das Set getrost kaufen, da du ggf. vermutlich rasch den richtigen Barwagen erhälst.
Grüße - Werner P
Hallo Werner,
vielen Dank für die Info. Ich hatte schon gar nicht mehr mit einer Antwort gerechnet. Dann werde ich mir wohl in nächster Zeit etwas "gönnen"😀.
Viele Grüße, Albert
Hallo Albert,
ja, gönne ihn dir! Aber höre dir vorher das Fahrgeräusch genau an. Sven Nikolaus hat bei YouTube eine Vorstellung des Modells mit Sound eingestellt.
Grüße  - Werner P
Hallo Werner,
danke für den Hinweis. Ich kenne das Video von Sven. Für mich kommt aber ohnehin nur die analoge Variante infrage.
Viele Grüße, Albert
Hallo in die Runde,
Ich greife diesen Faden wieder auf, weil ich recht günstig die 8-teilige, analoge Variante bekommen habe und überlege den Zug nachträglich mit Sound zu digitalisieren.
Das Video von Sven habe ich gesehen und in der Tat ist der serienmäßige Sound (von Zimo???) nicht so richtig überzeugend. Gibt es da mittlerweile etwas besseres?
Wie macht man das, wenn man den unmotorisierten Triebkopf auch zum "Dröhnen" bringen will?
Harti
Harti, Du brauchst den Zug einfach nur fahren lassen. Ich habe den auch in der Analogversion, und der ist so laut dass man vom Sound eh nicht viel hören würde
LG Mike
Also meiner ist (mit deaktivierten Sound) überhaupt nicht laut. Der Motorwagen ist so leise, dass man ihn auch ohne Sound meist nicht vom motorlosen Endwagen unterscheiden kann.
Was ist am Sound unglaubwürdig? Ich habe keine Ahnung, wie das Original (gibt's da ein Video?) geklungen hat, aber das Modell pfeift von beiden Enden wie eine Turbine. Ich bin normal nicht besonders empfindlich auf Fahrsound aber den hier muss ich ganz leise drehen weil einfach das Geräusch ansich auf Dauer unangenehm ist.
Genau wie im Motorwagen einen Sounddecoder und Lautsprecher verbauen. Beim RoFlei-Modell haben die beiden Decoder ab Werk einfach die gleiche Adresse. Was ohne Motor nicht geht: CVs am Programmiergleis auslesen. Ab Werk sind Zimo MS490 verbaut. Den gibt's nicht mehr, man kann aber genauso den Nachfolger MS491 nehmen.
Andi
Hallo in die Runde,
Vielen Dank für die Informationen.
Ich habe mir nochmal das Video von Sven angeschaut, der Sound scheint doch nicht so schlecht zu sein. Beim ersten gelieferten Zug hatte er wohl eher mechanische Probleme/Probleme mit der Stromabnahme.
Kann mir jemand sagen, wie groß die Lautsprecher sein dürfen?
Viele Grüße und einen schönen Sonntag
Harti
Passend wären gängige 15x11 mm LS. 3D-gedruckter Resonanzkörper o.ä. ist nicht notwendig, da dieser bereits im Ballastgewicht vorhanden ist.
Anschlussfähnchen der LS sind an sich egal, können symmetrisch oder asymmetrisch sein. Werden ohnehin ja nur Litzen/CuL-Drähte von/zum Decoder angelötet.
Die von diesel2k zu diesem Beitrag angefügten Bilder können nur von registrierten Usern gesehen werden - Login
Prima, danke für die Informationen.
Habe die Teile bei Fischer-Modellbau gefunden und bestellt.
Harti
